Pcakes55 Posted March 1, 2013 Report Share Posted March 1, 2013 All machine work was done at R&L Engines in Dover, NH; a very reputable shop around me. So here it is:F54 block - baked/blasted/jet washed- magnafluxed - passed- re-sized cylinders: 3.426 (.040 over)- drilled/removed oil galley plugs- R&R pressure bypassCrankshaft - checked/radius/micropolished- magnafluxed - passedP90 head - resurfaced : .006- drilled/tapped oil galley plugs- resurfaced valves and seats- new inner/outer valve springs- the camshaft was checked & micropolished, but they did not include it in the invoice, for whatever reason.Rods - mag'd - passed- rods & pistons R&R'dARP main and head studsMSA manifold studs kitCloyes timing chain kitEntire rotating assembly was balanced and jet washed. I have all receipts and records of work done, including the balance sheets and invoices. $1500 + shipping (cost me about $2700 to build) Patmccarthy55@gmail.com Link to comment
Pcakes55 Posted March 1, 2013 Author Report Share Posted March 1, 2013 Exhaust manifold and turbo distributor can be included with the sale; intake is sold. Link to comment
