intake for single 48mm dcoe weber
  • Replies 3
None of the manifolds are large enough for a 48mm carb.
B210 manifolds fit 40mm and some will also fit 45mm. To use 48mm you will have to bore out the manifold. It's all custom work once you are flowing that much air to run over 8500 RPM.
Pierce Manifolds out of California carry B210 manifolds
* 1xDCOE manifold for the oval port A14
* 1xDCOE manifold for the round-port A14 (5-speed cars)
