buster69 Posted September 14, 2012 Report Share Posted September 14, 2012 I just need the plate with the two holes that connects the latch mechanism to the actual window itself. I don't need the whole window. looks like part #17 & 18 on the sheet below. the one i need is for the right hand side window. Link to comment
69datsun510 Posted September 19, 2012 Report Share Posted September 19, 2012 Is it the bracket that actually screwed to the window frame? I rechromed some several years back, put one set on my chrome window frames in did for my son's car, before you could get the window frame rubber from DatsunSocal Mike. I may have a spare set, if that is the bracket you want. I will need to check to make sure, I know I have one set for my current project, but believe I may have another set or one odd ball one, not sure if its right or left. Let me know if that is the part first, then I will go out in the gauntlet of stored stuff in the garage. A picture of the leftside part would be helpful to positively identify the part for the thread. Thanks Link to comment
