620 clutch/brake pedal box assembly
  • Replies 12
I'm sure I have most of the parts you need, and I guarantee I have the pedal set somewhere. Make me a list of what you need and I'll look through my boxes. I no longer have any transmissions, though.
I need all of it really. I figured I'd pick up a 5 speed when I came across one, but the little stuff is harder to find. Pedals, clutch master and slave, L series flywheel.....
Let me know what you have and what you want for it. Thanks.
There is a 73 620 4-wheel drive at the PnP in Arlington. As of last week it still had the clutch and brake pedal in it, I happened to check. The clutch master and slave you would want to buy new, No reason to buy something youd have to rebuild anyway. I did this swap to my 75 620. It was pretty straight forward. . Good luck!
Awesome. I'll try to get down there this weekend. Thanks for the heads up!
You bet! Hey I can tell you that the one thing I had forgotten to grab off of the first couple of trucks I ravaged was the hard line that runs from the clutch master to the slave, Although am usually so excited to be yankin parts that I always forget something - its a little tricky to weave in and out, being a hard line.
Where abouts in Wa. are you?
