JBweld Posted June 27, 2012 Report Share Posted June 27, 2012 Looking to do a auto to manual swap. Let me know if you have a donor truck or see a truck in Pull-a-Part yard in NW Washington. Thanks. Link to comment
Icoblue Posted June 27, 2012 Report Share Posted June 27, 2012 I'm sure I have most of the parts you need, and I guarantee I have the pedal set somewhere. Make me a list of what you need and I'll look through my boxes. I no longer have any transmissions, though. Link to comment
JBweld Posted June 27, 2012 Author Report Share Posted June 27, 2012 I need all of it really. I figured I'd pick up a 5 speed when I came across one, but the little stuff is harder to find. Pedals, clutch master and slave, L series flywheel..... Let me know what you have and what you want for it. Thanks. Link to comment
ryknot Posted June 27, 2012 Report Share Posted June 27, 2012 There is a 73 620 4-wheel drive at the PnP in Arlington. As of last week it still had the clutch and brake pedal in it, I happened to check. The clutch master and slave you would want to buy new, No reason to buy something youd have to rebuild anyway. I did this swap to my 75 620. It was pretty straight forward. . Good luck! Link to comment
JBweld Posted June 27, 2012 Author Report Share Posted June 27, 2012 There is a 73 620 4-wheel drive at the PnP in Arlington. As of last week it still had the clutch and brake pedal in it, I happened to check. Awesome. I'll try to get down there this weekend. Thanks for the heads up! Link to comment
ryknot Posted June 27, 2012 Report Share Posted June 27, 2012 Awesome. I'll try to get down there this weekend. Thanks for the heads up! You bet! Hey I can tell you that the one thing I had forgotten to grab off of the first couple of trucks I ravaged was the hard line that runs from the clutch master to the slave, Although am usually so excited to be yankin parts that I always forget something - its a little tricky to weave in and out, being a hard line. Where abouts in Wa. are you? Link to comment
JBweld Posted June 27, 2012 Author Report Share Posted June 27, 2012 Thanks for the reminder on the hydraulic line. Where abouts in Wa. are you? The great metropolis of Ferndale. Link to comment
ryknot Posted June 27, 2012 Report Share Posted June 27, 2012 Thanks for the reminder on the hydraulic line. The great metropolis of Ferndale. Ah, I figured you had to be a bit north, seeing as you said - ill try to get "down" there. Welcome to Ratsun. Link to comment
chester Posted June 27, 2012 Report Share Posted June 27, 2012 I have a 73 parts truck with everything you need if you are still need anything. Just let me know. Oh I only have a flywheel for a. 6 bolt l20 Link to comment
JBweld Posted June 27, 2012 Author Report Share Posted June 27, 2012 Thanks for all the quick help everybody. Seems like a good group of peeps on here. I'm going to see what's left of the truck in Arlington, then go from there. Link to comment
Icoblue Posted June 28, 2012 Report Share Posted June 28, 2012 Alright. Hopefully I'll get into the back of the garage this weekend. Let me know what you still need after your visit to Arlington. Link to comment
ryknot Posted July 1, 2012 Report Share Posted July 1, 2012 Hey JBweld. Did you make it out to Arlington PnP this weekend? Link to comment
JBweld Posted July 2, 2012 Author Report Share Posted July 2, 2012 Hey JBweld. Did you make it out to Arlington PnP this weekend? Nope, some stuff came up, and I never made it. And I'll be out of town next weekend too, so it will have to wait I guess. Link to comment
