anthonydeb Posted June 18, 2012 Report Share Posted June 18, 2012 ok i looked everywere and it seemed so hard to do a alternator swap in my datsun iv got a 69 510 4dr with a L20b outa a 76 620 pickup after seeing some pretty crazy swap setups and custome brkates i whent down and bought a GM single wire alternator drilled out the tapped hole on it and it bolted right up to the stock mount on the engine used 1 washer to space it so the belt was straiter, and hooked up the one wire and havent had a problem with it after daily driving it for 2 weeks now. just though id let people know how easy it really is. Quote Link to comment
Pennvalleydimer Posted June 18, 2012 Report Share Posted June 18, 2012 If you use the 3 wire GM you can retain the warning lamp operation and the alternator is about half the cost. Side note, if you rev your L motor up a lot you can damage the bearings and or brushes. Those GM alternators turn a lot slower on a V8 due to a much larger diameter pulley. Jegs sells an underdrive pulley I recommend using.... http://www.jegs.com/p/JEGS-Performance-Products/JEGS-Billet-Alternator-V-Belt-Pulley/1943934/10002/-1 Quote Link to comment
Pennvalleydimer Posted June 18, 2012 Report Share Posted June 18, 2012 standard lookup would be an 85 chevy truck w/5.7L or 5.0L engine Quote Link to comment
