the carshop Posted May 1, 2012 Report Share Posted May 1, 2012 so i got in my truck last night and out of nowhere it just wouldn't start..... funny never had that prob before so i turn key a couple more times hear a click I'm thinking ok let me go hit starter a couple times.... poor starter lol i beat the crap out of it. it turns out i need a new ignition. still starts but very touchy so i need a new one soon and id rather give my money to someone here instead of ebay. let me know I'm in los angeles thanks. i need complete with key. thanks Link to comment
Icoblue Posted May 3, 2012 Report Share Posted May 3, 2012 Did you test the switch you have to make sure you need another? If it still starts sometimes, and other times you hear a single click when turning the key, my money would be on lack of current to the starter solenoid. Over time, the wiring in these old trucks degrades. When that happens, the resistance of the wire increases, resulting in a decreased current carrying capacity. If this is the problem you're having, you can easily fix it with a $5 relay and about $5 worth of wire from your local auto parts store. You can check your ignition switch by disconnecting the switched 12V wire from the starter solenoid, placing a voltmeter or multimeter between the wire (+ lead) and any known ground (I would recommend battery ground), then checking for at least 11V as a friend turns the key to start. It should be between 11.5V and 12.5V, depending on the condition of your battery. If you get no reading, it's probably your switch. If you get 12V, and it isn't ever cranking, it's probably the starter or solenoid. If you get anything less than 11V, and it starts sometimes, it's your wiring. Installing the relay should fix the problem. Even if the wiring isn't your immediate problem, the relay will help your truck start perfectly every time, and is a cheap mod everyone should install. There is a thread in the how-to section that explains how to install it. Link to comment
Icoblue Posted May 3, 2012 Report Share Posted May 3, 2012 Oh, and if you still need an ignition switch, I have one I can sell you for $15 plus shipping. It's new, but not Nissan factory.. I forget the brand. It has 2 keys, no box. Link to comment
the carshop Posted May 3, 2012 Author Report Share Posted May 3, 2012 ya i got a shop we checked it the next morning and that was it for sure. Link to comment
the carshop Posted May 3, 2012 Author Report Share Posted May 3, 2012 you can even feel it in the key. u gotta turn it just right to hit that spot then hold it there. ya ill take the ignition pm me thanks Link to comment
ggzilla Posted May 3, 2012 Report Share Posted May 3, 2012 Sounds like you need the ignition switch, not the key lock. Before 1979 they were combined. 620 for 1979 had seperate units. $12 at RockAuto Link to comment
