SKkeeterZ Posted December 14, 2011 Report Share Posted December 14, 2011 1993 hardbody non tach dash, speedo doesn't work neither is the odometer all the dash lights and other gauges work Any one have experience with this? Would this be a cable issue Quote Link to comment
frey1691 Posted January 18, 2012 Report Share Posted January 18, 2012 Yea the odometer, trip odometer, and spedo are all one unit driven by the spedo cable. There is a series of gears that run each part. If you pull your gauges out and completely disassemble the cluster when you pull out the spedo you will see what I mean. From my experience most cables are just broken and need replacing but every once in a while I get lucky and it's just disconnected :P Quote Link to comment
