twotoedbandit Posted November 12, 2011 Report Share Posted November 12, 2011 LoOking for an a14 head for my 78 b210. Casting number h72. Anyone have one they want to part with or know where I can find one? Thanks Link to comment
JAS Posted November 12, 2011 Report Share Posted November 12, 2011 I have an H62 or 620 off an A13 that will fit, same exact head, except it is for a dry intake system. Will fit and work, same valve sizes etc... I have dissasembled, the head has only about 60K orignal miles on it. $100.00 plus shipping, you would need to get new valve stem seals for it for less than $10.00. Seats are good, valves, springs, keepers, pushrods come with it used,, you re-install them. I am in Caldwell ID. ALso have original intake/exhaust, and requilt carb for it. I installed an H89 head that i had shaved/ported/polished with its intake exhaust manifolds and a weber carb, that is why i have all this extra sitting around. Another $80.00 for the above + shipping costs. if interested. All pre-smog. Link to comment
ggzilla Posted November 12, 2011 Report Share Posted November 12, 2011 H62 has smaller ports and is from the A13 engine. But will physically fit. Performance will be slightly lower at peak RPM. There might be a small inversion problem because the A14 manifold is larger. It might be a superior head below 4000 RPM, I would just lightly grind out the last 1/4" of the ports to match the manifold. Will it fit the A14 smog equipment? Link to comment
twotoedbandit Posted November 13, 2011 Author Report Share Posted November 13, 2011 I will definitely consider it. Have a lead on a h72. If that falls through I will shoot you a message. Thanks. Link to comment
