NAchatty Posted November 12, 2011 Report Share Posted November 12, 2011 Ok, i have been looking at getting some new wheels after i get my suspension fixed on my 280z, but have no idea if they will fit without some modification? http://949racing.com...-6ul-black.aspx 15x8 +36 offset 12.3 lbs 4x100 67.1mm center bore i have always liked the way they look and am thinking about getting them, i know i will have to get adapters to run the 4x100 lug pattern (30mm possibly? or whatever i can get to work), my problem is i know pretty much nothing about what will fit. i know guys running 15x8 with 0 offset but with these being +36 and needing adapters i am completely lost to be quite honest this is really just a tentative idea just checking out options any input would be greatly appreciated Quote Link to comment
Stupid_fast Posted November 12, 2011 Report Share Posted November 12, 2011 30mm 4x100>4x114.3 adapters will make the 36mm offset ... 6mm... Quote Link to comment
NAchatty Posted November 12, 2011 Author Report Share Posted November 12, 2011 30mm 4x100>4x114.3 adapters will make the 36mm offset ... 6mm... wow...that makes since now. Thanks! ok, so i shouldnt have a problem fitting them so they dont hit anything, or is that +6 going to to cause an issue? Quote Link to comment
Stupid_fast Posted November 12, 2011 Report Share Posted November 12, 2011 wow...that makes since now. Thanks! ok, so i shouldnt have a problem fitting them so they dont hit anything, or is that +6 going to to cause an issue? AFAIK +6 8" wide should be fine, but I don't own a Z. Quote Link to comment
NAchatty Posted November 12, 2011 Author Report Share Posted November 12, 2011 AFAIK +6 8" wide should be fine, but I don't own a Z. haha sweet, but like i said its not definite just gathering ideas Thanks for the help! Quote Link to comment
