codyethridge Posted October 6, 2011 Report Share Posted October 6, 2011 I have a set of 3screw SU carbs that I can no longer use. These are the carbs that came on the later 240z late 71-73. These carbs have been completely taken apart and cleaned to perfection. (and put back together) Theses carbs look brand new, And are garrenteed to work. They are using the 260z manifold, It bolts up just like the 240z manifold except the runners are larger, therefor It should perform a little bit better than stock. The intake manifold has all the ugly emissions equipment removed, coolant lines, EGR and associated hardware and parts. AN EGR block off plate has been made for it.. These carbs will bolt up to any L6 motor from 1970-1983 and make your engine compartment look way better in most cases. Sale Includes 240z air cleaner box, Fuel rail, all the linkage and all associated hardware. Parts not included are fuel lines. The price is 300$ obo. If you would like to Call/ text to get more info/ negotiate price please do not hesitate My # = 601 721 2078 . View pictures here> http://codyethridge....rbs__head#xmGaU. I am located in Tucson Arizona Also If you happen to have a fuel injected car with a suspected broken EFI system, Bolt theses carbs on and get a low presure fuel pump and it'll run. Link to comment
Sealik Posted October 6, 2011 Report Share Posted October 6, 2011 Any play in the throttle shafts? Link to comment
codyethridge Posted October 7, 2011 Author Report Share Posted October 7, 2011 Any play in the throttle shafts? Very minimal. I can measure it if you would like, It will be in a day or two though, ILL have to go buy a dial indicator. Link to comment
