DailyDato Posted August 26, 2011 Report Share Posted August 26, 2011 I have a 77 620, I did a DE swap, and now having some wiring problems, I completly forgot....... On my wiring harness, it runs from the passanger fender behind the battery, and down, Where my cables should have gotten spliced into the harness, Which wire is my positive, and which is the negative, like right where the wires come out of the body harness and get connected to the battery, both my wires are black, and my schematic, is wrong.... Quote Link to comment
DailyDato Posted August 26, 2011 Author Report Share Posted August 26, 2011 ok, cut open my harness, and found out, but now i have bigger issues, I did the ka24de swap, and wired it exactly how everyone says to do it, runs great, ignition switch works fine.....most of the time if i start my truck, and turn the headlights on, and then attempt to turn the key off, it keeps running until you turn off the lights, any ideas??? any one? Quote Link to comment
