cksubs Posted August 22, 2011 Report Share Posted August 22, 2011 The bumper itself will come off with no problem. It's the metal spacer/filler piece thing that's welded to the body that's giving me trouble. Used snips to cut the 4 metal pieces underneath. Thought that would do it, and I'd be able to easily hammer it off. Nope, seems to have multiple welding points the entire width of the car. Got through one with a hack-saw blade inserted between the bumper and the car, but it took 30 minutes for one and there are probably 15+. Any good advice? Quote Link to comment
MegatherioN Posted August 26, 2011 Report Share Posted August 26, 2011 You can use spot weld drill bits if you want to do it professionally I cut mine with a hammer and a chisel. 1 Quote Link to comment
cksubs Posted January 8, 2012 Author Report Share Posted January 8, 2012 Finally had some time to work on this, and got it off pretty easily.... although the remaining area is unfortunately now pretty rusty and will need some body work! For anyone attempting to remove the space/filler metal piece, I took some heavy-duty tin snips and cut the metal piece into 20+ thin strips. Cut them all the way back to the edge of the car. Then took pliers and basically rip/twist the metal away. WEAR GLOVES. It's easy to take all the pieces off that aren't welded to the car. Just leave those ones on for the time being. You'll be left with 8 or so spot-welded strips. Use a horizontal or circular path with the pliers to break the welds. Water definitely gets between the car and the spacer if the paint is bad at all, so be ready for some rust. But even so, looks SO much better without the rear bumper. Quote Link to comment
ComicArtist Posted January 9, 2012 Report Share Posted January 9, 2012 I just grabbed mine after I removed the bumper and wiggled it a lot until the spot welds broke. Then I used an angle grinder to smooth the weld spots, and sanded and primed the whole rear panel. Still have the indentions and bumper holes, but I kinda like 'em. Character and stuff. Quote Link to comment
afbrian13 Posted January 10, 2012 Report Share Posted January 10, 2012 I don't know why, but the one on my 76 and a 78 I worked on came right off. Maybe I got lucky. Does look a ton better without that bumper! Quote Link to comment
