Topher88 Posted May 31, 2011 Report Share Posted May 31, 2011 I purchased my spindles alone with no calipers and purchased everything else new. I just need a little reference to look at for the brakes and would like to know each of the bolts torques. I know the spindle nut is something like 18-22 lbs. Quote Link to comment
Sinnful Posted May 31, 2011 Report Share Posted May 31, 2011 What do you want to know about the brakes? On that stuff I don't torque any of that stuff, I just make sure its tight, and if you have a doubt on if its tight enough use some blue loctite Quote Link to comment
Topher88 Posted May 31, 2011 Author Report Share Posted May 31, 2011 Ok that's pretty much what I have been doing. On the brake pads there isn't a braket on the back to hold It in but I got two little clips with the calipers but I'm not sure where they go an If those are the only things I need to hold the pads in. Quote Link to comment
Sinnful Posted May 31, 2011 Report Share Posted May 31, 2011 Ill take a pic of some 280 struts I have, give me just a few......... Quote Link to comment
ggzilla Posted May 31, 2011 Report Share Posted May 31, 2011 There is a procedure to adjust the wheel bearing. Do not simply torqe it. Use the tepair manual. Quote Link to comment
Topher88 Posted May 31, 2011 Author Report Share Posted May 31, 2011 From what I read you have to slowly tighten the nut while rotating the hub. thanks for taking some pics. I have a feeling I'm missing something from my pads like a shim that gose on the back of each hub l. Quote Link to comment
Stupid_fast Posted June 1, 2011 Report Share Posted June 1, 2011 Dunno if its OK to post these here but... Quote Link to comment
Topher88 Posted June 3, 2011 Author Report Share Posted June 3, 2011 Dunno if its OK to post these here but... you rock dude! thanks man Quote Link to comment
