rusty510 Posted January 26, 2008 Report Share Posted January 26, 2008 thought i would start off with a little contribution to this forum. here is a litst of 510 part #s i have that might be of use to some of you guys. well here goes. duralast water pump W/ fan clutch # bwp-511 cardone water pump w/ fan clutch # 55-63711 valuecraft reman # m57-1028 transpro radiator # 433487 beck arnley water pump gasket # 039-4011 felpro water pump gasket # 25569 earls plumbing brake bleeder screw # 280022erl fenco reman brake caliper Pass # c8530 driv # c8531 brake drum beck arnley # 083-0349 duralast # 3521 brake hose front brakeware # 88566 beck arnley # 073-0200 brake hose rear brakeware pass# 77645 driv#77003 beck arnely right hand# 073-0218 left# 073-0192 russell brake line - metal (4per kit) #686500 front brake pads duralast # d37 beck arnley # 082-0118 front brake rotor duralast # 3101 brake shoe rear duralast (9x1 9/16" brakes) # 359 beck arnley # 081-0192 beck arnley clutch hydrolic hose (slave hose) #073-0218 motormite clutch pilot tool # 14501 wheel cylinder brakeware # 33731 beck arnley # 072-5242 clutch master beck arnley # 072-6521 brakeware # 11795 clutch slave beck arnley # 072-1233 brakeware # 10029 distributor cardone reman # 31-602 beck arnley # 185-0031 nissan part # 21200-p7991 thermostat kit for l,z,a,e,ca engines nissan part numbers: 27091-a4605 heater control valve (69-73?) 27095-a2301 heater control valve 68 only heater inlet hose # 27020-a0800 heater outlet hose #27021-a0800 heater core # 27014-a4600 rear side window latches #76860-a1400 hood latch # 65610-21400 hood release cable # 65630-21402 datsun 510 koni front shock inserts Part # is 82R 1715 KOYO Front Wheel Bearings Nissan Datsun 200SX 300ZX 510 #BR6/2 kontrolle idler arm bushing kit part # 3353103 ---------------------------------------------------------------- well i hope that these will help some of you! Quote Link to comment
rusty510 Posted January 26, 2008 Author Report Share Posted January 26, 2008 also some diagrams and a picture of an oem fuse box, for those of us whose isnt readable or is non existant! Quote Link to comment
