L24E no power
BOOTS83
ok 1977 810 L24E inline 6 fuel injected
parts replaced=
fuel pump,fuel regulator,fuel filter,1 bad injector,some fuel line
plugs,wires,cap,rotor,coil
air filter,oil
battery
things checked=
vacume is 100%
fuel and spark are good
maf and tps seem to work(or at least do something when adjusted)
problem=anything over half throttle results in a choking effect,no stall just no more power and a vacume suck type sound quickly
smells rich sometimes
seems as if it is not running on full power/all cylinders
when stopped i can put the pedal to the floor up until 15 mph then it chokes,,power before that 15 is not what it should be tho
idles fine,anything over that is ruff
seems to run better when colder outside but just barely
have messed with all adjustments,maf,idle,timing nothing gets rid of it
any ideas?..i might add that the alt is only keeping the battery level,,not charging it to the top but that is getting replaced soon
  • Replies 0
