Pineapplegti Posted October 5, 2010 Report Share Posted October 5, 2010 Alrighty opened the dash up today to find out why stuff doesn't work and had a few questions that couldn't be answered by the haynes manual.. 2 red and black wires that are soldered to ignition switch housing... i get 12 volts at one and ground at the other.. Im assuming these are for the buzzer ? Green wire with a double connector coming out of the harness near the fan switch.. I assume this is related to the radio ? Quote Link to comment
Pineapplegti Posted October 5, 2010 Author Report Share Posted October 5, 2010 Also can anyone lead me to the tach loop wires in the dash ? I know its the two white wires from the tach but i cannot find the wires it is supposed to connect to ? maybe a color code? Btw got the temp and gas gauge working .. and starts with a key vs gay starter button.. found out i need a new turn signal switch.:blink: Quote Link to comment
qwik510 Posted October 5, 2010 Report Share Posted October 5, 2010 Also can anyone lead me to the tach loop wires in the dash ? I know its the two white wires from the tach but i cannot find the wires it is supposed to connect to ? maybe a color code? Btw got the temp and gas gauge working .. and starts with a key vs gay starter button.. found out i need a new turn signal switch.:blink: IIRC, there are not tach loop wires in the dash. There was a special harness that you could by that would run from the coil to the dash. It is easy to hook up the tach, just run 2 new wires yourself. This article tells you how to hook it up. http://dimequarterly.tierranet.com/articles/tech_tachrepair.html Quote Link to comment
Pineapplegti Posted October 6, 2010 Author Report Share Posted October 6, 2010 Thanks.. that is what i planned to do but wanted to be sure first.. Quote Link to comment
dgi Posted October 6, 2010 Report Share Posted October 6, 2010 Also can anyone lead me to the tach loop wires in the dash ? I know its the two white wires from the tach but i cannot find the wires it is supposed to connect to ? maybe a color code? I wrote this up a while back. Maybe it will help you. PL510 inductive tachomether hookup Quote Link to comment
Pineapplegti Posted October 6, 2010 Author Report Share Posted October 6, 2010 That helps alot.. thanks :) Quote Link to comment
