ZXR Posted September 23, 2010 Report Share Posted September 23, 2010 I AM ISO 1990 TO 1995 VG30E 4X4 ENGINE COMPLETE. I DON'T NEED THE WIRING HARNESS. AS I WILL BE GOING WITH THE HOLLEY 500CFM CARB AND INTAKE MANIFOLD. I'M JUST LOOKING FOR A DEAL ON THE ENGINE COMPLETE. INSTALLING INTO MY 1987 HARDBODY 4X4. WHICH CURRENTLY HAS THE NAPZ ENGINE. I WILL ALSO BE NEEDING THE BELL HOUSING FROM THE SAME YEARS VG30E TRANSMISSION. MY PLAN IS TO ADAPT THE VG30E BELL HOUSING TO THE STOCK 4 CYLINDER TRANSMISSION. SO THAT I CAN RUN THE VG30E ENGINE WITHOUT HAVING TO SWITCH OUT EVERYTHING ELSE. SINCE I AM ALSO GOING WITH THE www.vg30.com INTAKE MANIFOLD TO RUN THE HOLLEY 500CFM CARB, I WON'T NEED THE WIRING HARNESS. PLEASE LET ME KNOW WHAT YOU HAVE OR KNOW OF SOMEONE WHO HAS SOMETHING. I MAY BE WILLING TO TRADE FOR MY NAPZ ENGINE COMPLETE. I ALSO HAVE A HOOKER HEADER FOR THE NAPZ. THANKS! ERIK - 360-798-8893 Erik.Hansen36@gmail.com Link to comment
fisch Posted September 23, 2010 Report Share Posted September 23, 2010 Hi Erik. Curious what path you chose for the distributor in your set-up? Wish we could get the Saudi dist here! Good luck on your hunt! Link to comment
