510 Caliper mounting brackets
  • Replies 5
Factory stock means you're referring to the front, right?
On a PL510 the caliper mount bracket is an integral part of the knuckle/spindle
forging welded to the bottom of the strut, so there's no separate bracket. Caliper
mounting holes are 76 mm or 2.992" apart, or 3.00" for all practical purposes.
If you're working on an HL510 ('78 to '82), I don't know if they have a separate
bracket or not. 610's have the same style integral mount as PL510's with the same
3 inch/76 mm bolt spacing. Not sure what setup 710's have.
Actually, I think I know what he's looking for / referring to, and I believe it IS a separate piece.
I have a set here, let me go shoot a couple pics. BRB. :)
Let me know if this is what you need. They're brand new (copper brake part lube on friction surfaces).
yes that is what i am looking for.Just the brackets tho not the caliper plate part or whatever. Does it have hardware with it??
I have the bolts that attach to the hub / spindle, yes.
PM me your address, you can have them cheap.
