WTB 510 Fuse Box Screw
  • Replies 5
It's a plastic snap screw thing that always ends up broken. Yours probably just
broke and fell out.
A solid redesign I came up with is to tap 3/8" SAE coarse threads in the plastic hole
and use a 3/8" wing-bolt (like a wingnut, except a bolt). Use a fat rubber o-ring
or rubber washer under the head to hold torque against the fragile plastic cover.
I think the existing hole is oversize for a 3/8" tap, so the threads cut will be
shallow. Mine were deep enough for the light finger-tight torque you use
for this. There may be a little ridge you need to file off at the top of the hole.
7/16" SAE coarse would produce deeper threads but is a less common size.
th_100MEDIA_IMAG0021.jpg?t=1276648334th_100MEDIA_IMAG0022.jpg?t=1276648334
I used a plastic rivet that holds plastics on quads or dirt bikes. push in once to lock farther in to release. I have a few extras give me your address and i can send you one.
Pretty cool man. What are those called so I can look for some. Thanks for sharing!
If you go to a cycle gear they have plastic rivets for fairings for street bikes or dirt bikes. They stock 6mm and 8mm what you want is the 8mm only thing that sucks is that they come in a pack of like 6 and they run about $6.00 but its not a bad idea to keep extras for yourself or a homie.
