73 pick em' up Posted May 12, 2010 Report Share Posted May 12, 2010 just have a quick question, which way should the distributer rotor be facing in a 77 620 and should it be at top dead center in the compression or exhaust stroke thank you Quote Link to comment
MicroMachinery Posted May 12, 2010 Report Share Posted May 12, 2010 At TDC on compression stroke, it should be facing the #1 spark plug wire. Quote Link to comment
jefe de jefes Posted May 12, 2010 Report Share Posted May 12, 2010 http://web.archive.org/web/20050312092651/home.att.net/~jason510/Dizzy_FAQ.htm 1 Quote Link to comment
73 pick em' up Posted May 12, 2010 Author Report Share Posted May 12, 2010 #1 spark plug wire from the block or distributer side Quote Link to comment
SurgeL320 Posted May 12, 2010 Report Share Posted May 12, 2010 http://web.archive.org/web/20050312092651/home.att.net/~jason510/Dizzy_FAQ.htm Thanks for posting this jefe! Quote Link to comment
MicroMachinery Posted May 12, 2010 Report Share Posted May 12, 2010 Distributor side. Follow the #1 spark plug wire back from #1 spark plug; Where the wire plugs in on the distributor, that's where the rotor should be pointing. Quote Link to comment
jefe de jefes Posted May 12, 2010 Report Share Posted May 12, 2010 Thanks for posting this jefe! :thumbup: Quote Link to comment
73 pick em' up Posted May 12, 2010 Author Report Share Posted May 12, 2010 thank you Quote Link to comment
jefe de jefes Posted May 12, 2010 Report Share Posted May 12, 2010 Skip towards the end. I think Hainz covers what your looking for. http://www.guba.com/watch/3000024223/Hainz-Datsun-L-Series-Engine-01-Timing-Tare-down-and-Rebuild Quote Link to comment
