Glimited Posted November 25, 2007 Report Share Posted November 25, 2007 City:Bothell State/Province:WA Price:Obo+$- Item Description: I have two CA18DET Transmissions both in good working order, two CA18DET complete motors one without a turbo or coil packs though... One of the motors has a spun rod bearing (this motor also has a set of 460cc injectors in it as well as a HKS metal head gasket), the other motor has a blown head gasket as far as i can tell (has an SR T25 installed on it). I have 2 CA18DET ECU's, one CA18DET harness, one CA18DET MAF's, S13 manual drive line, Shortend shift lever (was chopped down a little and re welded), And various other parts for the CA18DET. If you don't see something that your looking for let me know i might have it. Transmissions: $300ea Motors: One with spun rodbearing, HKS MLS, and 460cc Inj's $450 Motor with blown head gasket $350 Wiring Harness $200 ECU's $100ea Drive line $125 CA18DET down pipe $50 (this is a stock down pipe for the CA18DET) Link to comment
Glimited Posted November 28, 2007 Author Report Share Posted November 28, 2007 Price change Transmissions: $250ea Harness: Will come with dropping resistor and ignitor (forgot to mention that earlier) (ignitors seperatley $100ea) CA18DET AC with bracket: $25ea Motors: One with spun rodbearing, HKS MLS, and 460cc Inj's $350 One with blown headgasket $300 Link to comment
Glimited Posted December 7, 2007 Author Report Share Posted December 7, 2007 Bump Transmissions $200ea Link to comment
Glimited Posted December 25, 2007 Author Report Share Posted December 25, 2007 BUMP! $150 for CA18DET Transmission, need it gone. Link to comment
