what Posted January 20, 2010 Report Share Posted January 20, 2010 Hi. I live in salem oregon. Iam looking for a rear sway bar for a 620. Have cash and or paypal. Thank you. Link to comment
motavated Posted January 20, 2010 Report Share Posted January 20, 2010 Hi. I live in salem oregon. Iam looking for a rear sway bar for a 620. Have cash and or paypal. Thank you. The only company who makes them is called Addco and its sucks. You can buy it and if you make it work tell me cus I dont fucken get it at all. Worst 200$ ever spent... Instead I got some awesome advice from Yello620 and doing what he did on his truck. Ok, here is an old update. Installed a rear sway bar from a Nissan Pathfinder. Guessing that it was about a 1990 model. Was from a 2 door Pathy, not the later 4 door. I dont know if that matters though. The bar was a freebie, so i thought i would try it. I purchase axle saddles for trailer axles from the local steel/trailer fabrication shop and added a couple of holes. Angle cut the ends so they didnt look so bulky, then welded them to my axle housing. Sorry, no pic of this. I didnt like how the sway bar angles came out with the pathfinder end links, so i found some shorter ones from a Nissan Sentra(93). I made a mount to weld to the frame near the spare tire for the end links. This sway made a HUGE difference in how the truck drives. Maybe 50$ 100$ tops? Or you can gets the PCD bars... Ok guys & gals i decided now's the time to make a few sway bars & try & sell a few. I was supposed to make one for Lynch420 last year but life got in the way [i still owe you one:D]. This part will bolt directly onto a leaf spring rear suspension. The models i know for sure it'll fit are..520, 521, 620 & 510 wagon. If you own a B-210, 1200 or any other Datsun w/ leaf springs your axle may be narrower. In that case i can simply change the dimensions so it'll fit your car. I will supply the brackets & all hardware needed to install it. I made my 1st one today for Mario [71dimer] & it only took a few hours. Also keep in mind i can make different center section designs just let me know what you want. Ok the pics........... center design top bar is 1 piece BTW center design is welded from behind so you get a clean look. brackets welded in place & then a few coats of primer I can also paint them w/ automotive paint / clearcoat. Prices are $100 in primer & $125 painted. This includes shipping unless you live in Europe :lol: I also work for trades so lemme know what you have. Fuck it install both if you like. JUST DONT BUY THE ADDCO UNLESS YOU WANT TO SUFFERRRRRR!!!! Link to comment
