bigjoe619 Posted November 30, 2009 Report Share Posted November 30, 2009 Hey fellas where is a good place to ground the battery when relocating the battery to the trunk of a 510 2 door? Quote Link to comment
qwik510 Posted November 30, 2009 Report Share Posted November 30, 2009 Hey fellas where is a good place to ground the battery when relocating the battery to the trunk of a 510 2 door? I put a bolt through the inner fender well and hooked it up to that. I put a thick rubber washer on the the bolt (to keep any water out) and installed in from inside the fender well with the threads sticking into the trunk area. I removed the paint on the inside of the trunk around the bolt area and then placed my ground wire over the bolt. Then a flat washer and a nylock nut and it was good. :D Quote Link to comment
