jefe de jefes Posted November 27, 2009 Report Share Posted November 27, 2009 L series matchbox dizzy-$80 shipped. Comes with pedestal,plug for module, and extra module. I'm at work:(and can't post pics from my phone. I can email pics so pm me with an email addy if you would like to see them. Link to comment
hessianben Posted November 27, 2009 Report Share Posted November 27, 2009 I need a matchbox diz that has an intact plate below the points. The plate is usually black plastic with small arms that hold single ball bearings. it allows the smooth movement of the vacuum advance arm. you can see it if you remove the rotor and look around the points. many matchboxes have broken ones. if it is intact, i'm interested. Link to comment
jefe de jefes Posted November 27, 2009 Author Report Share Posted November 27, 2009 (edited) I need a matchbox diz that has an intact plate below the points. The plate is usually black plastic with small arms that hold single ball bearings. it allows the smooth movement of the vacuum advance arm. you can see it if you remove the rotor and look around the points. many matchboxes have broken ones. if it is intact, i'm interested. huh? Lol I can check during my lunch hour if it hasn't sold by then. Edited November 27, 2009 by jefe de jefes Link to comment
jefe de jefes Posted November 27, 2009 Author Report Share Posted November 27, 2009 sold! Link to comment
