electronic dizzy - matchbox
  • Replies 5
I need a matchbox diz that has an intact plate below the points. The plate is usually black plastic with small arms that hold single ball bearings. it allows the smooth movement of the vacuum advance arm. you can see it if you remove the rotor and look around the points.
many matchboxes have broken ones.
if it is intact, i'm interested.
huh? Lol
I can check during my lunch hour if it hasn't sold by then.
Edited by jefe de jefes
