Smiley720 Posted November 2, 2009 Report Share Posted November 2, 2009 (edited) O.K. it was a busy weekend in the garage and got alot done but nothin quite finished. I did get a ton of candy as I took a couple hours off and went trick or treating with the kiddies. Ultra smooth pumkin Rising Sun Lower bar tabs installed Edited November 2, 2009 by Smiley720 Quote Link to comment
Smiley720 Posted November 2, 2009 Author Report Share Posted November 2, 2009 putting in upper bar crossmember getting closer Quote Link to comment
slam_dat_sun Posted November 2, 2009 Report Share Posted November 2, 2009 Looking real nice , keep us posted and keep busy :lol: Quote Link to comment
denveratsun Posted November 3, 2009 Report Share Posted November 3, 2009 Hey man...I love the progress! use the good days we are supposed to be having to your advantage! I am going up to the mountains for a few days, but when I get back, lets hook up about those 17s...I would love to see them on there. Lookin good!:cool: Quote Link to comment
Smiley720 Posted November 3, 2009 Author Report Share Posted November 3, 2009 I agree...I want to see the 17's on it as well Quote Link to comment
Smiley720 Posted November 24, 2009 Author Report Share Posted November 24, 2009 Rear resanded and painted up nice All the link tabs on the rearend have been fully welded and the rearend has its new shiny paint job. Notch is still in the works... I need more steel Quote Link to comment
slam_dat_sun Posted November 24, 2009 Report Share Posted November 24, 2009 Hope you don't mind Quote Link to comment
Smiley720 Posted November 24, 2009 Author Report Share Posted November 24, 2009 looks kool Quote Link to comment
slam_dat_sun Posted November 24, 2009 Report Share Posted November 24, 2009 Here is another for your wife Quote Link to comment
Smiley720 Posted November 24, 2009 Author Report Share Posted November 24, 2009 Here is an old pic of me shaving the drip rail Quote Link to comment
lownslow Posted November 24, 2009 Report Share Posted November 24, 2009 Nice work Smiley. Here is one for you slam. Quote Link to comment
denveratsun Posted November 24, 2009 Report Share Posted November 24, 2009 man...those modified pics look really cool! So...are those certified welding spectacles you have on there?:blink: Quote Link to comment
RatRod25 Posted November 25, 2009 Report Share Posted November 25, 2009 Looks like you might get good amount of pinion change with that short of upper arms.. Did you run the links in reverse to keep the tank in the stock location? Quote Link to comment
Smiley720 Posted November 25, 2009 Author Report Share Posted November 25, 2009 The upper arms are alot longer than they look, and yes I wanted to keep stock tank for now, plus I always like the way the reverse links look Quote Link to comment
kaoss Posted November 25, 2009 Report Share Posted November 25, 2009 Boo reverse links! Just not worth it to keep the tank in the stock location. I would consider moving them forward before you get to far along. Quote Link to comment
airedout Posted November 26, 2009 Report Share Posted November 26, 2009 reverse links cause horrible handling and braking characteristics. With the upper links so short, it will cause your pinion angle to go way outta wack with the leverege setup of you bag placement. You will NEVER EVER hear anything about a reverse 4 link setup in any type of print suspension books. The reverse 4 link is only used by minitruckers that are to lazy to move the gas tank and use a proper 4 link setup. I would highly recommend that you move your tank, and setup a proper 4 link. Rear end looks nice! Quote Link to comment
denveratsun Posted November 26, 2009 Report Share Posted November 26, 2009 True...I think that "lazy" may be a bit strong...but totally true none the less. They say that no matter what you do..do it right the first time. This might be the time to do it right man.........I know it might suck for you right now, but it sounds like there is some good advice comin your way...:rolleyes: Airedout knows what he is talking about...you can tell by looking at his builds...might be the best bad news you ever got!:cool: Quote Link to comment
kaoss Posted November 27, 2009 Report Share Posted November 27, 2009 Here is a link to Bio Max's 4 link article: http://www.streetsource.com/forum/topic.aspx?topic_id=85853&Page=1 Hopefully you know who Bio Max is, and hopefully you have read it. If not, once you finish it, read it again. Great stuff. Quote Link to comment
airedout Posted November 27, 2009 Report Share Posted November 27, 2009 True...I think that "lazy" may be a bit strong...but totally true none the less. They say that no matter what you do..do it right the first time. This might be the time to do it right man.........I know it might suck for you right now, but it sounds like there is some good advice comin your way...:rolleyes: Airedout knows what he is talking about...you can tell by looking at his builds...might be the best bad news you ever got!:cool: Lazy is deff not a strong term. It is so simple to move the tank, there is no "oh, i think it looks cool", reverse links dont look cool, they look wrong, and they act wrong. It comes down to pure ignorance about how a suspension works. Reverse a "well designed" suspension, and it becomes a "poorly designed" suspension in reverse. It doesnt matter how correctly you think your reverse 4 link is setup, it is still wrong. period. Quote Link to comment
Smiley720 Posted November 28, 2009 Author Report Share Posted November 28, 2009 I read the article from Bio Max and it clearly states that there is nothing wrong with running a reverse 4-link. He said it holds the truck up, keeps the rearend under the truck and unless you are running buttlodes of horsepower (stock 1985 4 cylinder) then it is fine. Thank you all for your opinions. Quote Link to comment
kaoss Posted November 29, 2009 Report Share Posted November 29, 2009 He also says that there is nothing correct about it. Quote Link to comment
steve g Posted November 29, 2009 Report Share Posted November 29, 2009 for a lowrider on bags with 100 horsepower is fine with reverse 4 link.... not the best but its fine.... it may cause some ill handling but its not an auto-x car. Look at it this way.... many many 4x4s run a 4 link design on the front axles and it is technically reversed too... the arms run from under the frame forward to the front axle.. before we bash someones pride and joy factor in what its for... racing, show, dragging, shock value etc.... every design has its +s and -s Quote Link to comment
77 rustrat Posted November 29, 2009 Report Share Posted November 29, 2009 amen to each his own if you dont like it then dont look at it dont give him grief because of your dislikes all he wanted was an opinion not an arguement just drop it he likes it Quote Link to comment
airedout Posted November 29, 2009 Report Share Posted November 29, 2009 for a lowrider on bags with 100 horsepower is fine with reverse 4 link.... not the best but its fine.... it may cause some ill handling but its not an auto-x car. Look at it this way.... many many 4x4s run a 4 link design on the front axles and it is technically reversed too... the arms run from under the frame forward to the front axle.. before we bash someones pride and joy factor in what its for... racing, show, dragging, shock value etc.... every design has its +s and -s a setup in a 4x4 is also not adjustable. When you throw in changing your ride height, it changes everything. Im not bashing your truck by any means, im just trying to give you some info so that you can make an informed decision before you get too far. If you want to keep it reverse, you just need to be aware of the downfalls. If you were to move it forward, there are no downfalls. Also, i do believe max stated in his artticle that a poorly designed forward 4 link is better than the best designed reverse 4 link. Quote Link to comment
