86 720 Wiring Question - tachometer
LRAYVICK
I have an old tach I want to connect under the hood to set the idle speed prior to my smog check. I don't have a tach in the truck. I have looked over the wiring diagrams but I'm still confused.
There is a round 6-port "check" connector just in front of the coolant overflow tank. It has blue, black, yellow, and brn/bk wires. Can I use any of these to connect a tach? My tach is the old style dwell/tach meter with a hot and a ground connector.
The nice thing about investigating this today is I found a bad secondary coil connection which I fixed - the truck runs much better now.
BTW the epnet.com wiring diagram for 86 Nissan 720 2.4 L trucks does not appear to be consistent with my wiring.
(Don't know how to insert a photo of the connector or I would)
  • Replies 1
If i remember correctly, you can use a wire in that check connector, and i seem to remember it being the blue wire.
I have been wrong before so check a couple more wiring diagrams before you go letting the smoke out of your tach or wiring harness.:D
