PanzerAce Posted June 19, 2009 Report Share Posted June 19, 2009 So I've been tossing around a project in my mind for a super cheap 510 build, but I can't seem to find any info on the engine mounts for a CA motor. I've seen some posts on other forums that seem to indicate that the CA will mount up the same as a KA or SR, and that as such, any mounting gear for either of those engines will work. Can anyone here confirm that? (for DET and ET versions of the CA, if they are different block designs). Thanks. (And once it is in progress, pictures *will* be posted of the build). Quote Link to comment
