hoov100 Posted April 13, 2009 Report Share Posted April 13, 2009 Anyone have a couple pics handy of the z31T's inner CV bearing? (the one thats closest to the diff) and OD of the bearing cage? also need pics and dimensions of the z32 NA's inner CV axle (the side that bolts to the output shaft) and maybe the FSM pages to the axle assembly's?? what i am doing is secrete until i finish it and have it installed. lets say i want to mate the z32's output shafts to the z31 axle. WITHOUT having anything resplined or having custom axles made. :D any help is greatly appreciated! Quote Link to comment
240ADAM Posted April 13, 2009 Report Share Posted April 13, 2009 I would look around on hybridz, I've seen a lot of info on diffs over there. Quote Link to comment
hoov100 Posted April 13, 2009 Author Report Share Posted April 13, 2009 yeah, ive been searching hybridz the past couple of days, but have yet to turn anything up regarding mixing z31 and z32 axles. (also anyone who doesn't realize it yet you can swap short nose diff's into a long nose housing as long as you keep the ring and pinion from the long nose and the output shafts from the short nose [to keep the viscous coupling]) Quote Link to comment
Hyphy Posted April 14, 2009 Report Share Posted April 14, 2009 Been doin some of my own research on cv axles lately, driveshaftshop.com is what i found for custom stuff.. assuming you need it. Also havent found anyone that sells individual oem cv axle components, only entire assemblies :( Quote Link to comment
hoov100 Posted April 14, 2009 Author Report Share Posted April 14, 2009 I'm thinking the junkyard is gonna be y best bet to figure this out. Quote Link to comment
