datsunfish Posted March 16, 2009 Report Share Posted March 16, 2009 Trying to put together a L/Z23 motor and found that one of the pistons in my z24i got beat up a bit. It is ground into the side a bit which caused the ring gap to mushroom a bit and tighten up pretty bad. So I only need 1 and dont need the rod. Used in standard size would be great. I already ordered the rings and bearings and am about to drop the block off at the machine shop so the sooner the better. Thanks Link to comment
