180Bsss Posted March 4, 2009 Report Share Posted March 4, 2009 whats the torque and adjustment on the front wheel bearings on a 510 wagon? Quote Link to comment
Wharf Rat Posted March 4, 2009 Report Share Posted March 4, 2009 I don't know the spec but as a rule when changing a bearing you spin the wheel and tighten the nut to just zero lash or just until the nut wants to stop and it takes some force to tighten any further, then tighten it a eighth of a turn more. When just setting a old bearing run it up to zero lash and call it good. Grease is the most important thing and inspect the seal, replace if needed. Quote Link to comment
fiveoneohray Posted March 4, 2009 Report Share Posted March 4, 2009 Factory manual says: tighten nut to 20-22ft pounds spin hub several times tighten nut to 20-22ft pounds again back nut 90 deg. or until no play is present thats it. Quote Link to comment
180Bsss Posted March 5, 2009 Author Report Share Posted March 5, 2009 thx for the info i can put my wagon back together now Quote Link to comment
