I guess I could investigate cutting the 3rd pulley off on a lathe and just install the harmonic balancer. I'll check it out in the morning and see what can be done.
Thank you.
Jim
To make room when I install the ’92 KA 2.4 motor in my MG I need to remove the harmonic balancer pully (3rd pully) is that wise? Will the motor be affected by the lack of not using that outer pully with the harmonic balancer. I only need the middle pully for the water pump and alternator.
Thank you
Jim
'58 ZB Magnette
Looking for the adapter between the L20 distribitor and timing chain cover. Don't know the year. I am putting a L20B distribitor in a 1992 KA 2.4 motor. I have the correct oil pump spindle, I am looking for the adapter that holds the distribitor in to the timing chain cover.
Hood Rivre, OR 97031 area
Thank you
Jim
The '92 2.4 fan blade with the clutch removed has a 5.25 spacing on the mounting bolts ( diangle ). The water pump has a 2.37 diangle spacing. Do they make a spacer that allows the 5.25" blade fit the 2.37 water pump? ( less clutch )
Is there an adapter so I can install a '92 D21 2.4 Nissan plastic fan to the water pump with the clutch removed? I do not have the space in my '58 MG Magnette and the hood support and size does not allow me to install an electrci fan.
Thank you
Jim
Oops it's 60 mm or 2.37 inches. It sucks getting old and you read the small numbers wrong.
So, the smaller blades make a racket, maybe I'll go with an electric fan.
Thanks
Jim
I am trying to install a '92 D21 KA motor in my 1958 MG Magnette. Not much room so will a non-clutch fan from a 1973 620 fit the '92 KA water pump with the clutch removed?
The bolt holes on the pump are 6" apart at the cross section.
Thak you
Jim
Hood River, OR
Thank you for the update. I am trying to install a KA 2.4 motor in my 1958 MG ZB Magnette. The clutch will be really close to the frame. So, I was thinking about the Hydromex concentric internal slave. But I think I better stay with the original fork and slave unit.
Thanks
Jim
Has anyone installed a hydramax concentric internal slave cylinder in a KA D21 5 speed transmission? If so what brand and did you have any issues with installation?
Thank you
Jim Jans
Looking for an oil spindle to fit a KA 2.4 motor with a L20B distributor. I will use a KA oil pump and have the KA 2.4 timing cover.
I was told a Z20, Z22 and the Z24 or L20B spindle will work.
Thank you
I FOUND ONE, THANK YOU
Jim
