tiny
Everything posted by tiny
  1. tiny
    Flywheel specs?
    I'll try that, thanks! Probably worth a shot; starter is less than a year old but it's skipping like there's broken teeth somewhere, have yet to check though as I'm away from my vehicle.
  2. tiny
    Flywheel specs?
    Trying to find a flywheel for my 81 720 SD22. RockAuto came up short and only lists the ring gear for the gas engine which is incompatible. Any leads? ETA part number 12310-P0704 according to here.
  3. To clarify, this is how a manual choke engine should be started every time when it's cold? (like Van Island cold right now, between 5-8C in the morning) I've been having lots of cold start issues recently and just leaving it plugged in all the time to avoid dealing with it
  4. Yeah that’s what I’m thinking. Just stoked that someone can get it out of my garage
  5. Trying to ditch this bench seat, someone asked how much I’m selling it for. Free? $50? I can’t find a good metric online
  6. I found a couple indices for colour codes so I think Rallye Red is right. The interior is the black trim yes
  7. Would just like to confirm that the colour code 807 for my truck correlates to Nissan Rallye Red before I buy paint for touch ups! Does the “G”code for anything? Thanks in advance.
  8. Christmas project. Driver's side floorpan was completely replaced at some point but not well; both sides where covered with horrible fibrous insulation that held a ton of water. Cutting out all of the bad//recreating driver's side seat rail
  9. It sounds as if something is grinding while the engine cranks during cold starts. No issues when starting warm. Cranks slow but I had assumed this was due to lower temperatures and not due to increased resistance/burning contacts. Could it also be a misalignment with the ring gear on the flywheel or damaged gear teeth? Sounds pretty metal-on-metal. Thanks in advance!
  10. tiny
    Carrier bearing?
    Thanks! I'd probably use zip ties over buying OEM
  11. tiny
    Carrier bearing?
    Was doing an oil change and noticed my carrier bearing is looking pretty rough. Anyone have the part number for the replacement? Either the whole bracket/hanger or just the bearing/race I suppose. Rock Auto is overwhelming
  12. Managed to pick up an intact 81 720 bed in town with enough salvageable body panels to use for rust repair on the truck. And a tailgate!
  13. First time with the cap off. Try to ignore the peeling bondo from the previous owner
  14. Time Left: 11 days and 8 hours
    • WANTED
    • NEW
    Located on Van Island, Canada. Hoping for something nearby. Cheers!
    Ask for price
    Tofino, British Columbia - CA
  15. tiny
    Turn signal stuck on?
    Drove around 200km off-road with my 81 720 2WD without any issues, but once we hit an intersection we realized that when the right turn signal is flipped on, it just sticks and doesn’t blink (the green arrow just stays illuminated). Doesn’t happen on the left side. Haven’t really poked around, just curious as to if anyone else has run into a similar issue before! Thanks
  16. tiny
    D21 sway bar for 81 720?
    Also looking for a rear diff
  17. tiny
    Front sway? I'd be happy to pick it up on my way to Tofino this weekend. Message me details
  18. Body roll is crazy, found a front sway bar from an 87 D21. Compatible?
  19. Anyone know if this would fit? I want something with roof racks for sUrFboArds and love the windows. Not sure if this is where I should ask. https://www.facebook.com/marketplace/item/1457865737922321/?referralSurface=messenger_lightspeed_banner&referralCode=messenger_banner Thanks!
  20. Stoked that there are others on the island!
  21. Time Left: 7 days and 13 hours
    • WANTED
    • USED
    Looking for a white canopy for an 81 720 longbox. Brand irrelevant but keen on big windows and intact weatherproofing, minimal yellowing. Thanks!
    Ask for price
  22. Time Left: 7 days and 13 hours
    • FOR SALE
    • USED
    Takeoff from an 81 720. Mounts need to be straightened but it's an easy fix; right side is a little bulged likely from a knock prior to my ownership. I'd fix it but visually it's not super noticeable. I can ship/courier but I think it'd be expensive. Happy for offers
    $160
    Victoria - CA
