This is a issue ive been dealing with for quite a while now. Ive gone through 4 different starters. went cheap first, and decided to get a really good quality Gear Reducted starter. Sometimes it'll start fine (everything is timed accordingly by a timing light, and I have a brand new carb.) But the times it doesn't start up good, the starter will spin but bendix wont push out(atleast thats what it sounds like, I cant see inside the bellhousing) Anyway, ever since I had this truck the trigger wire that goes to the female spade connector on the starter always seems to be loose. Ive went through 4 different spades trying to get it to stay on there, I dont necessarily know if this would pose a problem, but ive ran a ground straight to the starter from the batter aswell as it getting ground from the bellhousing. I am getting very irritated by this because I just want it to work right. So if anyone has any suggestions on what it could be that would be very greatly appreciated. The flywheel looks fine, none of the teeth are chewed up. the starter is tight and sits flush up against the bellhousing. Ive done everything I could possibly do and checked everything. the only issue is the trigger wire. I think Im just going to void the warranty of the starter and Solder the wire onto the Spade connector thats on the starter. Thank you.
