Hello everyone. I’m at a loss with my clutch system at the moment. At this point I believe I have air in the lines but I’m either too dumb to correctly bleed it or there’s some other issue. Here’s the timeline.
I parked the car (that drove fine for the most part) in 2015 when I went away to school.
Fall of 2019 I got back to the car and started to get it going again. At this time I changed the thermostat, tore out interior that was falling apart, and did a temporary home paint job to stop some surface rust that had formed while the car sat. During this time I could move it around under its own power and had no issues with clutch. Wasn’t registered so wasn’t driving it much or very far.
Car sat again from around Feb of 2020 until two weeks ago when I went to get it smogged. This is when the issue began. There was no resistance to the clutch at all. Straight to the floor. I replaced the clutch master and slave cylinders. Tried gravity bleeding, vacuum bleeding, and reverse pressure bleeding and have made 0 progress. The rod coming out of the slave cylinder hardly moves if it moves at all.
When I last pressure bled it I made sure there was no air going into the bleeder screw and bled until no more air was coming up through the master cylinder and then some. Still nothing.
I don’t know what to do from here. About to take it to a shop but would rather spend the money on other things the car needs. Anyone else have a hard time with this?
