6 months later aint bad right?
So updates on the truck, we started working on getting the rear suspension sorted out:
I used a 6"Ø x 1/4" thick piece of pipe and a 3/16" plate to make the strut mount for the rear. This is pretty close to the Miata suspension geometry, but unfortunately I couldn't get it to sit inboard enough to run high offset wheels. Therefore, some new wheels were in order:
I ordered up a set of Rota Kyusha in 15x8 +0 offset. These were budget friendly and should work for the look I'm going for. One day the truck might get some nicer JDM wheels, but there is still a ton left to do.
Part of the reason we haven't been able to get much further than this is due to the rains in CA wreaking havoc on our work area. However, we were able to amass a bunch more parts thanks to winning an Ebay Motors sweepstakes:
Thanks to the sweepstakes, I now have:
- Garret GT2860RS
- Equal length manifold
- Aluminum turbo pipes
- Aluminum radiator w/ fans
- 40mm throttle body
- Limited slip diff
- Exedy clutch
- Harnesses
We also got some new tools:
- 1200 DV Tig Welder
- Roguefab tube bender & notcher
- Portaband with a table
We also received a generous amount of Ebay credit that will be going to supplies, an eventual engine rebuild, ECU, and some new seats. Those things are still a ways off though.
Other updates, I picked up a slightly newer Datsun pickup as well:
My wife & I traded in her old car for a 2023 Frontier Pro-4x. I thought it only appropriate to get a 2nd green Datsun pickup.
Hopefully now I'll have an easier time getting metal supplies, transporting parts, wheels, etc.
