Hi,
So, I bought this z24 engine block to use put it together it started knocking after a little bit
timing got messed up valves touched pistons
pistons and valves were fine and still hold compression
took it apart
replaced rod bearing and pistons rings
checked oil path ways reassembled.
knocking much quieter and only really hear when warm and at idle.
check the main bearings now. They arent great great copper is showing.
I have another z24i block with crank shaft installed that is known to be good(has no pistons but oil and water were mixing and it was not determined if the block was cracked or the headgasket was bad)
SOO
should I replaced the main bearings with the engine in the truck, measure clearances and not get crank shaft machined
OR
put the pistons from z24 block into the z24i block, because if I take out the z24 block to get the crank shaft machined.
I know what the right thing to do is but i don't want to keep dumping money and time into this truck and removing engines is difficult because I have to work in the dirt
Basically I dont have time to check the roundness of the crank shaft at this moment in time and dont want to worry about it constantly
I want to know the likely hood that the crankshaft needs to be machined if there was no visible scoring on it. If i could remove the crankshaft without removing the engine this would all be a non issue. Thank you for following me through this thought process.
