In reading the manual It uses a MAP Curve as opposed to Vacuum advance. I have no idea what this means but trying to learn. Local tuners indicated they can tune it for $700-$1000 on a dyno but I feel that’s how I got into this mess so trying to learn how to do it myself.
Regarding the vacuum curve, this is a little bit more complex. 123ignition works with absolute vacuum in stead of relative vacuum. The advantage of absolute vacuum is, it works also when you drive the car on high altitudes. In case of relative vacuum, you have to adjust the ignition manually. The values in the original Bosch graph are given in mmHg, 123ignition works with kPa. First we convert the values to kPa and crankshaft degrees instead of distributor degrees. You can type in Google: 80 mmHg to kPa
0 deg @ 11 kPa
10 deg @ 27 kPa
Now we have to convert the relative values to absolute values. Atmospheric vacuum at see level is 100 kPa. So 100 kPa is our base point. Al values below 100 kPa is vacuum all values above 100 kPa is pressure. in this case we have a vacuum curve, so our result will be:
0 deg @ 100 – 11 kPa = 89 kPa
10 deg @ 100 – 27 kPa = 73 kPa
