I just developed a new problem with my blinkers after fixing my speedometer: whenever I flip my blinkers to the left, they work perfectly normal. But when flipping them to the right, they blink much quicker, lights are dimmer, and both back lights blink while the correct front one blinks. The hazards work correctly. When I apply the brakes and flip the blinkers to the right, the indicator arrow stays lit up and no ticking noise is heard; however, applying the brakes and indicating left works as normal.
I have since replaced the flasher relay and this has solved two issues: the issue of abnormal ticking speed, both right and left flash at a normal interval, and the issue of dim lights while indicating right. The other issues remain, though, and it's weird because this problem just started yesterday; unless I was completely oblivious to it. Perhaps someone has had an issue similar and can point me in the right direction, or just educate me on the type of thought process required to solve these problems since I am not a skilled car person by any means.
