I'm just a tired of watching this truck rot, tired of suggestions likes "use the search function dumbass," would rather someone with the time and money buy the truck, needs a daily driver, type of guy.
Okay so I've got one on more solution I can think of for my issue with the brakes. I been reusing the copper washers/seals on the banjo fitting for the brakes, which turns out is a bit of a no-no. (I'm not very smart. Who knew?)
So as soon as the ice clears up I'll crawl back under the truck. Hopefully after that this will be a worthwhile thread.
So still can't get the brakes figured. With everything I've and I still don't have pedal pressure.
I have:
Replaced the master (bench bled) and wheel cylinders.
Bled the shit outta the brakes (nlsv too)
Checked for leaks.
Adjusted shoes.
Did some ghetto diagnostics and figured I've still got air trapped in the rear lines.
So this thread has been dead for a while.
Floor boards are only kind of shitty. Not too many holes but pretty thin overall. I sprayed a butt load of rust converter on it for now. That'll probably do me until I fab in new floor boards.
Brakes are almost done. Just need to adjust the shoes hopefully.
Just got to figure out how to tune a weber and I'll be on the road.
