RTB Posted November 23, 2014 Report Share Posted November 23, 2014 I'm trying to figure out how to correctly route the fuel lines if I plan on using a Holley pump. So I want to go fuel filter, pump, regulator with bypass, carbs. So I want there to be no return from the carbs and rather have the return go from the bypass regulator. Is this doable? Quote Link to comment
