blueribbon Posted August 3, 2014 Report Share Posted August 3, 2014 Hi all, I got a duel Mikuni side draft intake for my 73 610 because it is the short style and when the carbs are on it will not interfere with my brake booster like the longer cannon intake. Here is my issue: I cannot find and Mikuni 40's to save my life so if anyone has a pair sitting around, I would love to take them off your hands. It looks like I am going to have to put 2 Weber 40's on this manifold, which is fine I guess but I am concerned that the linkage will not work with the matchup. Has anyone had any experience with this issue and how can it be solved? Quote Link to comment
Mildsquare Posted August 16, 2014 Report Share Posted August 16, 2014 you can run weber's on the mikuni manifold without issue, you just have to get the proper linkage for everything, Ive seen the mikuni manifold with weber,mikuni,sk/oer carbs. you may just need to look for a linkage kit if you don't have all the needed parts. but if you have a complete manifold and get a complete pair of carbs you should have everything you need to be up and running. Quote Link to comment
