bloodontheapex Posted December 4, 2012 Report Share Posted December 4, 2012 It seems that I have enough parts laying around, Datsun and not, to have gone ahead and started to have crazy ideas for a new project. I have an L24 bottom end, seems to be from 1971. It's been rebuilt at some point in the past, bored 1 mm over. I would like to bore and stroke it. Perhaps I would not go larger than 2.8, since I doubt I can afford a diesel crank. I'm not sure if a bore past 86 mm is safe or worth the expense of custom pistons. I would like to remain in the realm of factory parts as much as possible. I suppose that L28 NA dished pistons would be best, bringing the compression somewhere around 8.3:1. I would like to use the E31 head I have available, but with larger valves and some port work. This head would raise the compression a bit, yes? I would like to be closer to 8.5:1. I suppose I could use a P90 head and flat tops, but I would like to use what is most commonly available and what I already have. The fun part: I have a pair of Zenith Stromberg carbs that I picked up from a friend in Norway. They were factory modified by Volvo for blow through turbo use. One carburetor fed a 1.9 litre single cam 4 banger with a Garret T3 turbo. They bolt directly to the L6 SU manifold. I would like to run both carbs with a 60 Trim T3 whatever intercooler I can find to fit. I'm not sure at this point if these carbs would provide too much fuel for a 2.8, and if the needles would have to be changed. If they have to be changed, that would be a real bummer, since they're specific to these carbs and were never available in the US. Utilizing L28ET, L24, L28E parts, I believe this engine could be built almost completely with OEM parts. What to y'all think? How quickly would I explode this junk yard collage? Any thoughts or experience with methanol/water injection would be apperiated. Quote Link to comment
