mindtab Posted July 16, 2011 Report Share Posted July 16, 2011 FINISHER ASSY-REAR PANEL LICENSE PLATE HOLDER W/ LIGHTS OEM. No cracks, chips, dents. Very light fade bottom rim. Lights work, no chips,cracks. License plate lights:DOT IKI 6056 Japan L SAE L78. (LH 16B ) (RH 16A) $90.00 for whole assembly. or $75 for frame alone. Lights separately: $20 ea. Location: S.California Link to comment
mindtab Posted July 16, 2011 Author Report Share Posted July 16, 2011 LH Driver Side Taillight OEM. DOT SAE AI(2) S(2)T 78 IKI 4234 Made in Japan. And another inscription: IKI 7088 eR-287 Working lights, clean, no cracks, chips; tiny almost invisible (have to hold to light to see) scratch lines here and there on the reflector plastic; paint around frame rim edge faded in places, as can be seen in the picture. No rubber seal between plastic reflector and frame . $80.00. Location: S. California inside Link to comment
mindtab Posted July 16, 2011 Author Report Share Posted July 16, 2011 RH Passenger Side Taillight OEM. DOT SAE AI(2) S(2)T 78 IKI 4234 Made in Japan. And another inscription: IKI 7088 eR-287 Working lights, clean, no cracks, chips; tiny almost invisible (have to hold to light to see) scratch lines here and there on the reflector plastic; paint around frame rim edge faded in places, as can be seen in the picture.No rubber seal between plastic reflector and frame. $80.00 Location: S. California inside Link to comment
mindtab Posted July 16, 2011 Author Report Share Posted July 16, 2011 LH / RH (Passenger & Driver side) REAR BACKING LIGHTS OEM. DOT SAE R 78 IKI 4244 Made in Japan. Working. No cracks, chips, dents. Great condition. $40.00 for both or $25ea. Location: S. California Link to comment
mindtab Posted July 16, 2011 Author Report Share Posted July 16, 2011 LH / RH (Passenger & Driver side) REAR-PANEL SIDE MARKER LIGHTS RH Passenger side: SAE AP2 78 IKI 5060 Made in Japan. Excellent condition. $30.00 LH Driver side: same part no. Surface crack line at bottom, by the screw; crack does not go through the whole plastic cover, it's solid without wiggle or movement. $20.00 Both rubber covers/frame in excellent condition. or $45.00 both. Location: S. California Link to comment
