slinginabullet Posted February 19, 2011 Report Share Posted February 19, 2011 In the need of 24e upper and lower alt brackets and t stat housing junkyards are slim pickins these days Link to comment
AuosGnaf Posted February 19, 2011 Report Share Posted February 19, 2011 In the need of 24e upper and lower alt brackets and t stat housing junkyards are slim pickins these days I'm assuming you're looking for these parts to run a single belt on your KA swap? I was in the same boat and then I found a guy on CL selling a SOHC KA and asked if I could just buy the upper and lower brackets. He was reluctant, but $30 later they were in my hands (I know I got robbed, but I needed them). CL search 240SX's in your area and you might get lucky. If you find a SOHC KA see if you could just buy the brackets. In regards to a T-stat housing.... you can either use the one you have and shave a little off from where the belt hits the housing, junk it, or hit up one of the franchise auto stores. I shaved mine. Just be careful. Hope this helped. Good luck! Link to comment
