rikgray Posted May 8, 2010 Report Share Posted May 8, 2010 Schwitters 5 speed dog box with Nissan Bell Housing Removed from my SCCA GT3 Nissan in excellent condition Clutchless shifting. Extended input shaft. Hewland straight cut rem finished close ratio gear set. Only 46 pounds Schwitters uses Alfa cases with Hewland gears. Many ratios available Adapter with Nissan - Datsun bell housing with Tilton hydraulic bearing. (was running with Quartermaster 2 disk clutch) Package $4,500 rik at zpeedz dot com L series bell housing Perfect for L16 - L20 or? 0.619" input shaft 1" x 10 spline ratios effective: 1.81, 1.57, 1.33, 1.15, 1.00 H pattern, short input shifter rod on trans, no extensions just r & r, this trans is a gem Link to comment
