RadioRedline Posted February 27, 2010 Report Share Posted February 27, 2010 Hello! I ordered a replacement turn signal assembly for my 1974 620 from ebay. It arrived, and it seems there are 2 styles according to my haynes manual: Version 1: 8 wires (1 separate wire for horn, 1 for power, and a small 6 prong niles plug) Version 2: 7 wires (1 for power, and a large 6 prong niles plug, one of those 6 on the plug in this version runs the horn) My yellow 74 has factory hi and low beam and uses the 7 wire/version 2. The signal lever has 5 positions left turn, right turn, off, hi beam, low beam. My red 74 (the one that needs the new signal) has a hi and low beam clicker installed on the floorboard aftermarket. The signal indicator lever only has 3 positions left turn, off, and right turn. I looked on ebay again, and I have been looking for probably a year for the correct part, anyone have an extra signal assemby that has 7 wires instead of the usual 8? Thanks in advance Radio Quote Link to comment
mr68gts Posted February 27, 2010 Report Share Posted February 27, 2010 I might have one out of my 73 I'm going to part out soon. No guaranteed it works though. I bought the truck not running for a cabchange over. Quote Link to comment
RadioRedline Posted February 27, 2010 Author Report Share Posted February 27, 2010 Lol that would be awesome! My signal still works, its just broken arm. So I can make one out of two sorta thing then. You know for sure its a 7 wire? Radio Quote Link to comment
mr68gts Posted February 27, 2010 Report Share Posted February 27, 2010 I wa going to take column apart but raining today. Ill see if I can get under it tomorrow and find out. It should be a 7 wire though. Paul Quote Link to comment
RadioRedline Posted February 28, 2010 Author Report Share Posted February 28, 2010 I wa going to take column apart but raining today. Ill see if I can get under it tomorrow and find out. It should be a 7 wire though. Paul Thanks Man! Woo signal! Radio Quote Link to comment
