clutch810 Posted July 23, 2009 Report Share Posted July 23, 2009 so as you have seen my 620 does not have a fuel tank. i managed to get one out of a junk yard and got it running today, finally got to wash off all the spiders and what nots that have inhabited my truck. i found a mouse in my exhaust when it turned over, too bad my cat wasn't out for batting practice it would have been a home run. either way, i have 4 hard lines running back to the end of the frame one is brakes the other is fuel in, i found out the the other is fuel return (all over my garage floor) and then i have one other, does any on know what the last one could be??:confused: Quote Link to comment
Guest DatsuNoob Posted July 23, 2009 Report Share Posted July 23, 2009 You should post your location on your profile. When I pulled mine, it looked as though there was one going back toward the fill tube. I think it may be some kind of breather line for filling (kinda like that vent cap on the back of a gas can)? I'll check my 620 manual tomorrow if nobody answers for sure. Quote Link to comment
