volksmike Posted May 28, 2009 Report Share Posted May 28, 2009 I was cleaning the inside of the bed of my truck. And I saw that the water was seeping through there seams to the outside... So, if your inside bed seams are missing the calk, then you are going to have rust issues on the outside paint... Quote Link to comment
whitechef Posted May 29, 2009 Report Share Posted May 29, 2009 We used to use stuff called "drip check" I think it was from 3M. Quote Link to comment
Weaver Posted May 29, 2009 Report Share Posted May 29, 2009 Tada: http://www.eastwoodco.com/jump.jsp?itemID=1595&itemType=PRODUCT Kind of hard to seal the seams though when the inside and outside of your bed is rusty. haha Quote Link to comment
volksmike Posted May 29, 2009 Author Report Share Posted May 29, 2009 You can wire brush, then put on some of that rust paint stuff. Like master series, por 15, rust bullet, etc. If you use por 15, you have to paint over it, 'cause the UV rays kill it after awhile. Then use a paintable calk sealent, or body seam seal. Quote Link to comment
